fixing my mistakes
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
fixing my mistakes
Permanent link to this post Posted by luv2readaloud » Fri Nov 17, 2017 3:02 pm
Hello, I am sure this has been covered but i have searched for this in every way I could think to ask it and didnt find what I was looking for so I am going to ask.
OK so I record audio books (working on my first) I have figured out almost everything except in my editing. when my author gets back with me about a miss-pronunciation I go and record my fix, and insert it in the file. Here is where my problem starts I can never make it sound the same. I know there has to be a way to match the corrected audio to the rest but for the life of me I cant get it to blend in. here is an example of my problem :oops:
Thank you for any help you can give me and also for all the help I have been able to get using your fourm
untitled.wav
(156.29 KiB) Downloaded 8 times
luv2readaloud
Re: fixing my mistakes
Permanent link to this post Posted by kozikowski » Fri Nov 17, 2017 3:31 pm
Very few people can get a word to slide in gracefully. Re-record the sentence or segment of narration that has natural breaks so the difference won't be as obvious.
We can't tell much from two seconds, but it sounds like you changed the face/microphone distance. That's rough to manage in post production. I have appeared briefly as two different people by just changing the microphone distance. It's a very serious sound change.
Again, two seconds isn't much, but it's a common new-user error to think they have to "live record" a correction like that. Make a protection copy of the "broken" work and announce the correction by just pressing record. Audacity should produce a second track with the correction on it. Tune which track to listen to with the SOLO and MUTE buttons.
Then use the Time Shift Tool (two sideways black arrows) to slide the corrected word into position, and the envelope tool to mute the old word at the right place. Audacity will smash both tracks together when you export.
http://manual.audacityteam.org/man/envelope_tool.html
This lets you add or subtract time, effects, and volume to the correction without affecting the main work. I would have increased the time between the existing and the correction, for example, which is relatively easy when they're two separate tracks.
And all that is why it's best to re-record the whole sentence or paragraph. It's far easier to hide minor changes like that.
Have you run into the ACX quality control services yet? We warn people not to record the Whole Book only to discover ACX won't accept your sound quality.
Permanent link to this post Posted by luv2readaloud » Fri Nov 17, 2017 3:51 pm
Yes some of your other posts of been a huge lifesaver as far as ACX goes I usually do record a section or symptoms like you suggest but I still can’t ever get it to sound the same I I don’t know if I speak differently or what it is exactly I do but it never sounds the same and it frustrates me because I’ve had to re-read entire chapters because I can’t get it to blend close enough and then they find more errors in my new recordings but I fix the old ones it’s extremely frustrating to me and it almost has me wanting to just give up I can post a better sample in just a minute
luv2readaloud
Permanent link to this post Posted by kozikowski » Fri Nov 17, 2017 4:09 pm
It's not the easy, fluffy job many people think it is.
You can post up to twenty seconds of mono (one blue wave) work on the forum.
Describe how you're recording your voice. It's not unusual for the computer's built-in corrections and tools to be "helping you" when that's the last thing you need. Computers are business machines not generic tools they used to be. You spend a lot of time turning off built-in corrections that may work OK in a conference to the head office, but sound terrible in an audiobook or podcast.
http://manual.audacityteam.org/man/faq_ ... hancements
http://www.kozco.com/tech/audacity/Test ... _Clip.html
Permanent link to this post Posted by luv2readaloud » Fri Nov 17, 2017 4:16 pm
here is a reread though a section didnt do much it so you can advise me master lol :D
I have a headset microphone that I am currently using, audacity is my program, i use the nyqust script you and steve recomend nd the limiter
I didnt expect it to be a real fluffy job it was something I have had a desire to do.
luv2readaloud
Permanent link to this post Posted by kozikowski » Fri Nov 17, 2017 4:26 pm
I don't see a sound clip.
Permanent link to this post Posted by kozikowski » Fri Nov 17, 2017 4:35 pm
There is a much more exotic way to do this. Use the musical overdubbing techniques (record all the instruments in a song one at a time).
Listen to the original track from the beginning of the segment and read right along with it so you have exactly the same rhythm and volume and announce the correction when you get there. Much better than trying to announce the correction cold.
That could take more effort to set up and get used to than may be worth, but that is another way. That's a cousin to "smash recording" which is an older technique Audacity can't do. Play the older work and smash record on the tape recorder when you get to the fluff.
Permanent link to this post Posted by luv2readaloud » Fri Nov 17, 2017 5:23 pm
sorry I guess my file was to big but here it is.
untitled.wav
(1.85 MiB) Downloaded 8 times
luv2readaloud
Permanent link to this post Posted by DVDdoug » Fri Nov 17, 2017 6:00 pm
This won't help you...
I saw a clip on TV of an author recording his audiobook. There was a producer monitoring on the other side of the glass and every once in awhile, the producer would stop him and ask him to start-over (I think at the beginning of a paragraph). And sometimes, he would give him "hints" on pronunciation, etc. Everything was corrected immediately so it was the same setup and the same "voice". The "tape" was never stopped. The paragraphs/sections were numbered and I believe the author would announce each paragraph/section so everything was easy to keep track of and it was easy for the producer to tell him were to re-start. And, I'm pretty sure the producer was keeping notes on his copy.
This particular author had an advantage in that he was a radio/TV professional so he was used to being behind the mic every day.
DVDdoug
Forum Crew
Permanent link to this post Posted by kozikowski » Fri Nov 17, 2017 6:21 pm
There's a 2MB limit to forum posting. That's either 20 seconds of mono (one blue wave) or 10 seconds of stereo. If you need to post longer WAV samples, you have to do it using third parties such as DropBox
The longer posting is very highly compressed and processed. It's not a "clean" recording and that's one reason different passes for different corrections don't match.
There's a quality of talking into and out of a wine glass typical of excessive noise reduction, or Windows conference processing.
Listen carefully on headphones just after about 13 seconds. You take a breath between spoken phrases, but the sound is strangled like a bad cellphone.
That may pass automated quality control, but it will never pass Human QC.
See if anything here helps.
If that sample was more or less plain recording, then Windows is poking its fingers in it.
Next
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 8 guests
