Audacity 2.2.0 installation issue
and the exact three-section version of Audacity from "Help menu > About Audacity".
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
Permanent link to this post Posted by s malik » Fri Nov 03, 2017 10:21 pm
I had Audacity 2.1.3 on my system. I installed the latest version 2.2.0 over it. Then, there were two entries of Audacity in Apps & features. I uninstalled Audacity 2.1.3 from Apps & features, it actually removed version 2.2.0. Then, I tried uninstalling the Audacity 2.2.0 and it gave me an error shown in the attached snapshot. Then, I installed version 2.1.3 and I was able to uninstall it successfully. I think Audacity should remove the previous version when overwriting with a newer version.
Apps & features.png (56.3 KiB) Viewed 185 times
Uninstall Error.png (10.58 KiB) Viewed 185 times
s malik
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], StrawberryClorox and 9 guests
