Chain conversion crashes Audacity 2.2.0
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Re: Chain conversion crashes Audacity 2.2.0
Permanent link to this post Posted by mrpond » Fri Nov 10, 2017 5:29 am
Hi - how do I get this fix? Is there a new version to download?
mrpond
Permanent link to this post Posted by Merowinger » Fri Nov 10, 2017 9:26 am
Is there a release date for the fixed version? Or a working beta version?
Merowinger
Permanent link to this post Posted by steve » Fri Nov 10, 2017 12:50 pm
For Mac, there is a "Nightly Build" https://www.fosshub.com/Audacity-Mac-Nightlies.html
Note that these are "alpha" builds, and although the current Nightly Build is the same as the release version plus a few bug fixes, that is not always the case. During the development cycle the Nightly Builds will frequently contain untested experimental features.
Nightly Builds for Windows were being made by Gale, who sadly passed away in August, so we don't have these at present. We now have a volunteer to take over building nightlies for Windows, and hope that we will soon have regular nightly builds for Windows.
We don't make binaries for Linux. For Ubuntu there is the unofficial "Panda Jim" PPA https://launchpad.net/~ubuntuhandbook1/ ... u/audacity
Permanent link to this post Posted by Merowinger » Fri Nov 10, 2017 12:51 pm
Okay, thank you.
Merowinger
Permanent link to this post Posted by mrpond » Tue Dec 05, 2017 2:09 am
Is there a version for PC I can download that is stable and contains this fix?
I am not a developer so need to know if this is something sensible to do, or if I should just deal with it crashing every time I apply a chain and wait for your next full release (2.2.1)
Many thanks for your advice.
mrpond
Permanent link to this post Posted by waxcylinder » Tue Dec 05, 2017 9:36 am
I suggest using the RC2 Release Candidate from here: https://www.fosshub.com/Audacity-devel.html
It's extremely close to being the release for 2.2.1 (the only differences will be a README file that was omitted for Linux - plus some additional foreign language updates)
waxcylinder
Permanent link to this post Posted by Merowinger » Tue Dec 05, 2017 9:47 am
Yes but I guess this bug (viewtopic.php?f=68&t=97963) is still in there. Until it's fixed I stay with version 2.1.3.
Merowinger
Permanent link to this post Posted by waxcylinder » Tue Dec 05, 2017 10:05 am
Merowinger wrote:Yes but I guess this bug (viewtopic.php?f=68&t=97963) is still in there. Until it's fixed I stay with version 2.1.3.
Yes that bug is still there (or the residual part that affects chains remains)
We managed to fix the non-chains use of File>Open to import a file so the the zoom to fit was restored - and will be in the upcoming 2.2.1 release
But we than discovered that there was a related bug that affected Chains: https://bugzilla.audacityteam.org/show_bug.cgi?id=1793
This remains unfixed and will not be in 2.2.1.
I'm surprised you say you are sticking with 2.2.3 - Steve Daulton, who logged this bug, reports that it is a regression on 2.1.2 - i.e he believes that 2.1.2 is the last version where this worked properly. :?
waxcylinder
Permanent link to this post Posted by Merowinger » Tue Dec 05, 2017 10:48 am
waxcylinder wrote:I'm surprised you say you are sticking with 2.2.3 - Steve Daulton, who logged this bug, reports that it is a regression on 2.1.2 - i.e he believes that 2.1.2 is the last version where this worked properly. :?
I guess you mean 2.1.3?
I use it daily and I can confirm the bug IS NOT there, at least not on my machine. The zoom level while using chains in 2.1.3 is correct.
Clipboard 1.jpg (106.81 KiB) Viewed 115 times
Merowinger
Permanent link to this post Posted by waxcylinder » Tue Dec 05, 2017 11:30 am
If you follow the link to the bug report in my previous post you will see that Steve definitely says it works in 2.1.2 but not in 2.1.3 :?
But nonetheless - whatever the version - it's still a regression. :(
waxcylinder
PreviousNext
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], kozikowski and 19 guests
