A minor issue.
- Open audacity 2.2.0rc1
- create something, say 1 minute chirp
- ^N to create a new project
- create something, say 1:30 noise
- pin it
- play it
- Alt-Tab (I’m on win10) to 1st project
- play it
Result:
1st project shows unpinned but plays pinned. I presume that the pin state is global, but is not updated across projects when it is changed. I don’t know if 2.1.3 did this, I’ve only just discovered pinning
Not a big deal.
Win10
Commit Id: 58f07d of Wed Oct 25 15:06:35 2017 -0400
Installed via .exe
Phil Mayes
Ooh so it does - good catch Phil
Just tested it on the proper 2.2.0 release version on my W10 Home laptop and indeed the same happens.
I’ll be logging this on our bugtracker (probably tomorrow as I have a gig to go to very shortly).
Thanks for reporting this.
I’ve logged this on Bugzill as P2 Bug #1769 “Pinned play-head button not updated across projects”: https://bugzilla.audacityteam.org/show_bug.cgi?id=1769
Once again thanks for reporting that Phil - and a nice clear bug report with clear “Steps To Reproduce” (do you fancy a part-time volunteer job as an Audacity tester?)
Peter.
Yes, I’d be happy to help out. I’m a semi-retired developer: assemblers/C/C++/Python, so I know what a bug report needs to contain.
