Mic recording different from direct speakers
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by das873 » Sun Oct 08, 2017 3:04 pm
Hello everybody!
I am new to this beautiful forum!
I am only a novice with audacity, so I post my first problem.
I am tring to register audio voicetrack for songs. I have a entry level condenser microphone, the Tonor pro with echo effect integrated.
Thi is attached to the pc through the standard 3,5 jack.
When I listen the voice directly with the speakers or the headphones, It looks pretty good. All the audible frequencies are reproduced directly. and very well.
But after recording many frequences disappear (especially the bass frequencies) and the voice sometime appears distorced. :o
What is the reason? :?
das873
Re: Mic recording different from direct speakers
Permanent link to this post Posted by DVDdoug » Mon Oct 09, 2017 5:28 am
This page may help.
DVDdoug
Forum Crew
Permanent link to this post Posted by das873 » Wed Oct 11, 2017 9:05 pm
Thank yoy DVDdoug!
That was the probem! Now the mic works perfectly!
Bye!
das873
Return to Windows
Who is online
Users browsing this forum: No registered users and 14 guests
