Is there a way to automatically add many tracks to one track one after another? Google only says how to do it manually with ctrl c and I have A LOT of tracks.
Import your tracks and they will stack top to bottom and all try to play at once.
Tracks > Align Tracks > Align End to End.
That should push each successive track to the right until it lines up with the one above. Since they all play at once, the new alignment will play them one after the other (change that with MUTE and SOLO). If you export the work, Audacity will jam them all together into one long song.
I didn’t know that was what that function did. Thanks for the tip – I will setup a project and try it out.
Be careful not to select any of the tracks. That will mess up the order mapping.
