RAW Header-less wav unsigned 8-bit PCM format
I am exporting audio data to RAW Header-less wav unsigned 8-bit PCM format. This should be a binary file so I expect to see binary data when I view it but it’s not what I see in my binary editor (EditPad Pro), I just see one long line of random characters. Does this file have a format that should be able to be viewed?
You’ve not said what data you expect to see, or what data you actually see, but it works OK for me.
Here’s a very short audio track (3 samples) and the hex values of an 8-bit unsigned RAW export:
I’ve never used EditPad Pro… Are you configured for viewing in hexadecimal? It should look like [u]this[/u].
All computer files are a binary!!! A hex editor will show the bytes (converted from binary to hex) and any value that can be converted to an [u]ASCII[/u] will also be shown as a character. For example, everywhere there’s a byte value of 65 (41 hex), you’ll see an ‘A’. The hex editor doesn’t know if the bytes represent audio samples, text, pixels, or a computer-program instruction in an EXE file, etc. And, in the case of 16 or 24-bit words, or floating-point values, the hex editor doesn’t have a clue how to re-construct those values. The application has to know the structure of the file and what the bytes represent.
“Real” audio data always looks random… (A real audio waveform looks pretty random too! :wink: ) That’s especially true with 16-bits or more or with stereo because you’re looking at 8-bit bytes and you can’t “see” where the actual samples are. If you have a sine-wave, square wave, or triangle wave, you might see a “trend”. But with 8000 samples per second or more, it’s generally impossible to get a mental picture of the waveform.
P.S.
Try [u]Sample Data Export[/u]. It won’t show you the raw bytes from the file, but it will show you the “normalized” (1.0 = 100% = 0dB) floating-point values used internally by Audacity, or the dB values.
