This morning I tried to install a plug-in (namely Chris’s Compressor) by taking the *.ny file, putting it in the plug-in folder and enabling it. So far so good: the plug-in shows up in the plug-in manager, I select it and click on “Enable”.
However, when I leave the manager menu and check under Effects, the plug-in doesn’t show up - and when I return to the plug-in manager, it again shows as disabled. I can repeat the process as often as I want, but enabling the plug-in never ‘sticks’.
Has anyone else encountered this kind of behaviour?
