I am looking for a method to achieve automatically finding the loop point in a song.
I don’t know for sure, but the parts I am comparing should be bit-perfect.
Basically, I have a song that has an intro part, then it plays the main part, twice, then there is a hard cut. I want to find out, where the song should loop to after the hard cut, based on the waveform.
For example, represented my audio as letter, it looks like this:
A B C D E B C D
So, in this case, I would want the song to go back to E, after the very end (which is D). Because there are two D’s present, I should be able to find and compare these and then the end of the first ‘D’ would be my loop point. I tried doing it manually, and it sounds very close but there is slight audio clip because it is not EXACT.
I really hope I am making sense. I am in a position where I would use this feature a LOT, and it would come in very handy for me!
