recording error
and the exact three-section version of Audacity from "Help menu > About Audacity".
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
recording error
Permanent link to this post Posted by timothydorgan » Sat Aug 26, 2017 10:13 pm
so just recently im getting the typical recording error check device and rate stuff. however its not all the time. if i open an old project its fine. if i open a new one it records fine unless i import an mp3 or wav than itll play but error if i try to record. even on older files itll record a few tracks than all of a sudden same error. i also use reaper and studio one and neither of these do it so it has to be something in audacity. ive used it for years now all of sudden this problem
Return to Windows
Who is online
Users browsing this forum: No registered users and 13 guests
