Problem exporting multiple tracks
Permanent link to this post Posted by peedee » Wed Aug 23, 2017 7:09 pm
Audacity thinks I haven't set up tracks, but I've already named each of the 10 pieces from the LP record I've recorded and saved it. Also, the Edit Metadata Tags only lets me enter info for track 1&2 and then immediately proceeds to export the entire file rather than the 10 separate files I am expecting to find on my PC. Using Windows 10, Audacity 2.1.3 and I downloaded the exe.installer. What have I done wrong?
peedee
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], tracer and 18 guests
