Request for API key using Scripting Module
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by ashwin.s320 » Thu Aug 10, 2017 9:08 pm
HI all,
Is there any way that I can get an API from Audacity to use within a Python code? I read about the scripting module which allows users to annotate and manipulate audio clips. What is the best way to implement this into the code?
ashwin.s320
Re: Request for API key using Scripting Module
Permanent link to this post Posted by steve » Thu Aug 10, 2017 9:17 pm
Do you have any experience building C++ projects?
The scripting interface is an optional module that is not built by default. The module needs to be compiled on the same day as Audacity for it to work.
The module is called mod-script-pipe. I've not tried building it for quite a while, but as far as I'm aware it should still work.
The code is included with the Audacity source code: https://github.com/audacity/audacity
There is some documentation for building on Windows here: http://wiki.audacityteam.org/wiki/Developing_On_Windows
If you intend to build Audacity from the source code and have not done so previously, there are some tips that I can give you that are not yet in the official documentation, so please ask.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
