Playback Cue List
and the exact three-section version of Audacity from "Help menu > About Audacity".
Playback Cue List
Permanent link to this post Posted by AaronMichael » Thu Aug 10, 2017 6:26 pm
Hello all,
I'm new to Audacity. Is there any way to set up playback of a number of different sections in a single audio file using a cue list. It is a feature in Cool Edit and very useful at times. I find no reference to setting up multiple selections and saving them with an audio file for playback. Thanks in advance for any help. Aaron WinXP
AaronMichael
Operating System: Windows XP
Re: Playback Cue List
Permanent link to this post Posted by DVDdoug » Thu Aug 10, 2017 6:54 pm
I don't think Audacity can make a cue sheet, and Audacity isn't supposed to be a "player" (although of course, you can listen to what you're recording/editing, etc.).
You can add labels if that helps.
Then for example, if you've digitized an LP or cassette you can label the songs and export each labeled section to a different song-file.
DVDdoug
Forum Crew
Permanent link to this post Posted by steve » Thu Aug 10, 2017 8:12 pm
Audacity does not use cue lists, but it does have "labels" that can be used to mark regions.
Information about label tracks here: http://manual.audacityteam.org/man/label_tracks.html
Permanent link to this post Posted by AaronMichael » Sat Aug 12, 2017 4:07 pm
Thanks for the information. It did not occur to me to search for the term "labels." Cheerio, Aaron
AaronMichael
Return to Windows
Who is online
Users browsing this forum: Google [Bot] and 8 guests
