inversion
and the exact three-section version of Audacity from "Help menu > About Audacity".
Re: inversion
Permanent link to this post Posted by kozikowski » Sat Aug 12, 2017 2:22 am
Marantz 660
Since you're the proud owner of a 660, how do you get the work into the computer? Thumb drive? Data Transfer Cable? Both?
Re: inversion
Permanent link to this post Posted by steve » Sat Aug 12, 2017 11:40 pm
How are you recording your voice?
Re: inversion
Permanent link to this post Posted by kozikowski » Sun Aug 13, 2017 1:04 am
Dynamic (moving coil) microphone plugged into an XLR to 1/8" stereo adapter and straight into the soundcard. It's almost certain this is producing out-of-phase stereo tracks by adapter mismatch.
It's also almost certain all these problems will vanish if they start using their 660 recorder which has direct XLR connections. That was the original recorder used by NPR in the field. Highly recommended.
We also know in other messages that TimKiska is looking at another microphone. I tried to be very firm that he post here before he writes a check. It may save us some work.
Re: inversion
Permanent link to this post Posted by steve » Sun Aug 13, 2017 1:17 am
Forum links just did something very weird there and missed off most of the forum thread :?
Re: inversion
Permanent link to this post Posted by kozikowski » Sun Aug 13, 2017 1:23 am
Did you offend it in some way?
Previous
Return to Windows
Who is online
Users browsing this forum: No registered users and 11 guests
