Only "Split Delete" Grayed Out
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by stlucifer » Thu Aug 10, 2017 12:56 pm
I found the other post on this site where the solution was to stop the playback. The audio is stopped, and for me Cut/Delete/Copy/Paste/Duplicate and some of the Remote Special items are all active - just the Split Delete is not enabled.
- Running on Windows 7 Pro 32-Bit, Intel i7-5820K @ 3.30 GHz
- Audacity version 2.1.3
See attached screen capture.
Example
Split Delete.png (46.65 KiB) Viewed 169 times
stlucifer
Operating System: Windows 7
Re: Only "Split Delete" Grayed Out
Permanent link to this post Posted by steve » Thu Aug 10, 2017 2:12 pm
stlucifer wrote:just the Split Delete is not enabled.
That's a bug. Split Delete should be available for labels and not just audio.
It's been fixed for the next release. In the mean time, use "Split Cut" instead.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 11 guests
