Unable to open AUP (Windows 10)
and the exact three-section version of Audacity from "Help menu > About Audacity".
Re: Unable to open AUP (Windows 10)
Permanent link to this post Posted by kozikowski » Thu Aug 10, 2017 11:00 am
If the project is a raw capture, particularly mono, then there is the possibility of rescue via the time and date stamps.
Editing scrambles the work inside the _DATA folder. Without the AUP file, there's no way to unscramble it.
Permanent link to this post Posted by dreamendedthisway » Thu Aug 10, 2017 11:00 pm
I will just have to learn from this and move on. Make something better. It was several multitracks.
dreamendedthisway
Permanent link to this post Posted by kozikowski » Fri Aug 11, 2017 1:14 am
Multi-track is rough. You can't use the common recommendation to export everything as backup WAV files. You could be there all week. You could Export a WAV of each track just after you perform it, and then go on to editing and production.
As you produce the show, Save Audacity Projects at time intervals under different names so Audacity doesn't try to keep stepping on and correcting one three-week old project.
You should know Audacity Projects do not save UNDO, so that's an important reason to have all the backup WAVs of each live performance.
Previous
Return to Windows
Who is online
Users browsing this forum: No registered users and 8 guests
