Unable to open AUP (Windows 10)
  • Please state which version of Windows you are using, the exact three-section version of Audacity from Help > About Audacity and whether you obtained the .exe installer or the zip.
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by dreamendedthisway » Wed Aug 09, 2017 7:08 pm
So, before anyone tells me I need to have my data folder present - I do. That doesn't even factor in. My issue is that when I try to open the aup file it tells me it is an audacity project and I should open it my using File > Open but I am. It doesn't matter if I open it directly, drag it in, ect. it always produces this message. I've been using audacity for years and this has never happened to me. I've tested it and some projects do open, some say this. I updated audacity and still nothing. Any help would be appreciated...
dreamendedthisway
Re: Unable to open AUP (Windows 10)
Permanent link to this post Posted by kozikowski » Wed Aug 09, 2017 7:54 pm
So you know already to actually reset Audacity with the tick box in the Windows installer? If you don't, Audacity will just install itself with your old preferences and settings, whether or not they're damaged.
That's just the beginning of the Things That Can Go Wrong.
Assuming you have a plain stereo or mono production, do you Export a WAV sound file backup in addition to the Project?
Have you tried to change the names of the Projects? You can't do that and the names have to match exactly the name burned into the AUP file. See: projname="
Do you like to put punctuation marks in your filenames? That's not recommended because that can give you unstable or unusable Projects. Only use _underscore_ or -dash-.
Try saving your Projects to your desktop, even only as a test. Some Audacity default installs caused Projects to save in the System area and operating systems don't like that.
What's a typical Project name? Could you have included a leading blank space or dot . by accident?
Permanent link to this post Posted by dreamendedthisway » Wed Aug 09, 2017 11:40 pm
Yes, there was actually a space in the original project name. I didn't realise that would be such an issue but that's probably what caused it to become unusable. Is there nothing I can do to salvage it? You said I can't change the project name.
dreamendedthisway
Permanent link to this post Posted by kozikowski » Thu Aug 10, 2017 12:17 am
Leading space? I don't think putting a plain space anywhere else matters.
What I meant was Normal Mortals can't change it.
First step: Make a backup of your AUP file and _DATA folder. Anything. Thumb drive. Make it so you can't damage them if something goes wrong.
Someone will correct me, but use the regular Windows tools to change the AUP file and the _DATA folder names to something correct, but they need to match. Open the AUP file in a text editor and change the projname=" name to whatever you called the AUP file.
This is what my Project looks like on my desktop.
Save the correction and see if the show opens.
I know someone is going to post about a step I left out, but if that's all you did wrong, I think that should do it.
Permanent link to this post Posted by kozikowski » Thu Aug 10, 2017 12:23 am
Please note that my graphic has Hollywood Magic to make the text look nicely laid-out, neat and orderly. That's for humans. Computers don't need that, so your file will be all crunched together and rough to read. Use the text editor search tool to find the projname=" entry.
Let us know, and let us know if there's more than one entry.
Permanent link to this post Posted by dreamendedthisway » Thu Aug 10, 2017 12:46 am
it seems that this has been a pointless endeavour and the file is completely unusable. I can open aup files in the text editor and see the code structure but when I open the one I want to repair it simply says NULL.
dreamendedthisway
Permanent link to this post Posted by kozikowski » Thu Aug 10, 2017 1:00 am
So you got the nuclear option where it's possible you interrupted saving the project before Audacity got done writing the AUP file. It does that last.
If this is an edited project, you're dead. If it's a raw, mono capture, there is a technique to try and rescue it. Which is it?
Permanent link to this post Posted by dreamendedthisway » Thu Aug 10, 2017 1:04 am
Nope, it's just dead. Empty file. I think a windows update might have screwed it up. Thanks for trying, though.
dreamendedthisway
Permanent link to this post Posted by kozikowski » Thu Aug 10, 2017 2:45 am
Let me do that again. Is this an edited Project? Forget the AUP file for a minute.
Permanent link to this post Posted by dreamendedthisway » Thu Aug 10, 2017 10:24 am
Yes, it is.
dreamendedthisway
Next
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 13 guests
