Problems with the "Noise Removal" plugin.
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by tocinin » Tue Aug 08, 2017 3:05 am
Hello... i'm new in this forum and... i'm having problems with my audacity :x
This is my sistem: http://i.imgur.com/x1HscDi.png
And... well this is my problem.
The Noise removal plugin... that plugin that comes with audacity... doesn't works for me.
It doesn't show an error or something... i just select my options (any options, it doesn't matter) and it doesn't works.
I tried to reinstall audacity but it doesn't fix my problem.
The plugin worked before... but now it doesn't works... i tried with different audios, and i tried with small ones but nothing :|
My version of audacity is 2.1.3.
tocinin
Re: Problems with the "Noise Removal" plugin.
Permanent link to this post Posted by kozikowski » Tue Aug 08, 2017 3:11 am
Audacity 2.1.3 doesn't have Noise Removal. That was the program in the old Audacity versions. Audacity 2.1.3 has Noise Reduction.
If you do have Noise Removal, where did you get Audacity from? This is the official supplier.
http://www.audacityteam.org/download/windows/
Permanent link to this post Posted by tocinin » Tue Aug 08, 2017 2:43 pm
kozikowski wrote:Audacity 2.1.3 doesn't have Noise Removal. That was the program in the old Audacity versions. Audacity 2.1.3 has Noise Reduction.
It's the same plugin... i have the original version from the official page... i don't know if my audacity have noise reduction or noise removal because my audacity is in spanish and i don't see the difference... but anyways... i can't fix my problem.
tocinin
Permanent link to this post Posted by steve » Tue Aug 08, 2017 2:50 pm
What settings are you using?
Try the default settings as shown here:
Permanent link to this post Posted by tocinin » Fri Aug 11, 2017 1:41 am
I tried with those options but it doesn't works...
tocinin
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
