Salve, dopo un paio di utilizzi del software, nella categoria EFFETTI è scomparsa la funzione “RIMOZIONE RUMORE”, che si trovava tra “rimozione clic” e “ripara”.
Ho provato a disinstallare il software, scaricarlo di nuovo e reinstallarlo, ma quella funzione continua a mancare.
Come devo fare per ripristinarla?
Traduci con traduttore google, non so l’inglese
Hi, after a couple of uses of the software, in the EFFETTI category disappeared the “NO REMOVAL” function, which was between “click removal” and “repair”.
I tried uninstalling the software, downloading it again and reinstalling it, but that feature fails.
How do I need to restore it?
The “Noise Removal” effect has been updated and the name changed to “Noise Reduction” (http://manual.audacityteam.org/man/noise_reduction.html). Sorry I don’t know what it is called in Italian, but it should be in the Effect list somewhere.
Do not try to remove ALL of the noise. If you remove ALL of the noise, it will sound bad.
Try to make the noise less without causing too much damage to the remaining sound.
The default settings shown here usually work quite well: http://manual.audacityteam.org/man/noise_reduction.html
To remove more noise, increase the “Noise reduction (dB)” amount. If the remaining sound becomes metallic / robotic, then you have probably set it too high.
