Quickly Joining Tracks
Permanent link to this post Posted by Vlad1321 » Sat Jul 15, 2017 2:00 pm
The “Mix and Render” function can join multiple tracks into one long track if the tracks are first aligned end to end below each other. However, when the “Mix and Render” function is used, it takes a long of time (more than one hour if many aligned tracks are mixed). Is there a way to quickly join all imported tracks into one long track without mixing and rendering them, which takes a lot of time?
Vlad1321
Re: Quickly Joining Tracks
Permanent link to this post Posted by Trebor » Sat Jul 15, 2017 4:18 pm
Vlad1321 wrote:... tracks are first aligned end to end below each other...
It's possible time-shift vertically: to drag all the tracks onto one track, end-to-end ...
Click on this animation to see it in its entirety
time-shifting vertically.gif (470.94 KiB) Viewed 354 times
Trebor
Permanent link to this post Posted by Vlad1321 » Sun Jul 16, 2017 8:19 am
Thank you for showing how to join separate tracks. Since I import many tracks into a project, is there a way to have the program join all of them automatically into one long tack?
Vlad1321
Permanent link to this post Posted by Trebor » Sun Jul 16, 2017 4:12 pm
Vlad1321 wrote:...I import many tracks into a project, is there a way to have the program join all of them automatically into one long tack?
That sounds like "append import" ... viewtopic.php?p=151858#p151858
Trebor
Permanent link to this post Posted by steve » Sun Jul 16, 2017 5:15 pm
Vlad1321 wrote:when the “Mix and Render” function is used, it takes a long of time (more than one hour if many aligned tracks are mixed).
Are you working with HUGE projects? For me, Mix and Render typically takes just a few seconds.
Return to Windows
Who is online
Users browsing this forum: No registered users and 6 guests
