audacity 2.1.3 can't use ffmpeg 3.3.2 avformat-57.dll
Downloaded audacity 2.1.3 portable.
Downloaded ffmpeg 3.3.2 shareable, both 32bit and 64bit, portable, from http://ffmpeg.zeranoe.com/builds/
Got ffmpeg link from https://www.videohelp.com/software/ffmpeg “view developers site”.
Went into Audacity → Edit → Preferences → Libraries and clicked ‘Locate’ for the ffmpeg library avformat-57.dll;
Navigated to my location and selected it, but it did not work.
Tried both 32bit and 64bit.
Does Audacity require v55 ie avformat-55.dll?
If so, the oldest version at zeranoe.com is v3.2 and it has avformat-57.
2 log files below:
For the 32bit ffmpeg avformat-57.dll
and the 64bit ffmpeg avformat-57.dll
log attempting 32bit ffmpeg avformat-57.dll:
Possible key lines:
16:19:14: Checking for monolithic avformat from ‘E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll’.
16:19:14: Error: Couldn’t find symbol ‘avutil_version’ in a dynamic library (error 127: the specified procedure could not be found.)
16:19:14: Error: Couldn’t find symbol ‘avcodec_version’ in a dynamic library (error 127: the specified procedure could not be found.)
16:19:20: Actual avformat path E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll
16:18:54: Audacity 2.1.3
16:18:54: Trying to load FFmpeg libraries...
16:18:54: mLibAVFormatPath ('E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll') is not empty. Loading from it.
16:18:54: Looking up PATH environment variable...
16:18:54: PATH = 'C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Chocolatey_nonadmin\bin;'
16:18:54: Checking that 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin' is in PATH...
16:18:54: Warning: FFmpeg directory 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin' is not in PATH.
16:18:54: Temporarily prepending ';E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin' to PATH...
16:18:54: Checking for monolithic avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
16:18:54: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: the specified procedure could not be found.)
16:18:54: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: the specified procedure could not be found.)
16:18:54: avformat not monolithic
16:18:54: Loading avutil from 'avutil-52.dll'.
16:18:54: Error: Failed to load shared library 'avutil-52.dll' (error 126: the specified module could not be found.)
16:18:54: Loading avcodec from 'avcodec-55.dll'.
16:18:54: Error: Failed to load shared library 'avcodec-55.dll' (error 126: the specified module could not be found.)
16:18:54: Loading avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
16:18:54: Returning PATH to previous setting...
16:18:54: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 0: the operation completed successfully.)
16:18:54: Actual avutil path
16:18:54: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 87: the parameter is incorrect.)
16:18:54: Actual avcodec path
16:18:54: Actual avformat path E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll
16:18:54: Importing symbols...
16:18:54: Error: Failed to load symbol av_init_packet
16:18:54: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
16:18:54: PATH = 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Chocolatey_nonadmin\bin'
16:18:54: Checking that '' is in PATH...
16:18:54: FFmpeg directory is in PATH.
16:18:54: Checking for monolithic avformat from 'avformat-55.dll'.
16:18:54: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
16:18:54: Loading avutil from ''.
16:18:54: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
16:18:54: Loading avcodec from ''.
16:18:54: Loading avformat from 'avformat-55.dll'.
16:18:54: Error: Failed to load FFmpeg libraries.
16:18:54: Error: Failed to find compatible FFmpeg libraries.
16:19:12: Attempting to load LAME from system search paths
16:19:12: Loading LAME from lame_enc.dll
16:19:12: Error: Failed to load shared library 'lame_enc.dll' (error 126: the specified module could not be found.)
16:19:12: load failed
16:19:12: Attempting to load LAME from builtin path
16:19:12: LAME registry key does not exist.
16:19:12: Library path is:
16:19:12: (Maybe) ask user for library
16:19:12: Failed to locate LAME library
16:19:14: Trying to load FFmpeg libraries...
16:19:14: mLibAVFormatPath ('E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll') is not empty. Loading from it.
16:19:14: Looking up PATH environment variable...
16:19:14: PATH = 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Chocolatey_nonadmin\bin'
16:19:14: Checking that 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin' is in PATH...
16:19:14: FFmpeg directory is in PATH.
16:19:14: Checking for monolithic avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
16:19:14: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: the specified procedure could not be found.)
16:19:14: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: the specified procedure could not be found.)
16:19:14: avformat not monolithic
16:19:14: Loading avutil from 'avutil-52.dll'.
16:19:14: Error: Failed to load shared library 'avutil-52.dll' (error 126: the specified module could not be found.)
16:19:14: Loading avcodec from 'avcodec-55.dll'.
16:19:14: Error: Failed to load shared library 'avcodec-55.dll' (error 126: the specified module could not be found.)
16:19:14: Loading avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
16:19:14: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 0: the operation completed successfully.)
16:19:14: Actual avutil path
16:19:14: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 0: the operation completed successfully.)
16:19:14: Actual avcodec path
16:19:14: Actual avformat path E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll
16:19:14: Importing symbols...
16:19:14: Error: Failed to load symbol av_init_packet
16:19:14: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
16:19:14: Checking that '' is in PATH...
16:19:14: Checking for monolithic avformat from 'avformat-55.dll'.
16:19:14: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
16:19:14: Loading avutil from ''.
16:19:14: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
16:19:14: Loading avcodec from ''.
16:19:14: Loading avformat from 'avformat-55.dll'.
16:19:14: Error: Failed to load FFmpeg libraries.
16:19:14: Error: Failed to find compatible FFmpeg libraries.
16:19:14: Looking for FFmpeg libraries...
16:19:20: User-specified path = 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'
16:19:20: User-specified FFmpeg file exists. Success.
16:19:20: Trying to load FFmpeg libraries...
16:19:20: mLibAVFormatPath ('E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll') is not empty. Loading from it.
16:19:20: Looking up PATH environment variable...
16:19:20: PATH = 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Chocolatey_nonadmin\bin'
16:19:20: Checking that 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin' is in PATH...
16:19:20: FFmpeg directory is in PATH.
16:19:20: Checking for monolithic avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
[size=120]16:19:20: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: the specified procedure could not be found.)
16:19:20: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: the specified procedure could not be found.)[/size]
16:19:20: avformat not monolithic
16:19:20: Loading avutil from 'avutil-52.dll'.
16:19:20: Error: Failed to load shared library 'avutil-52.dll' (error 126: the specified module could not be found.)
16:19:20: Loading avcodec from 'avcodec-55.dll'.
16:19:20: Error: Failed to load shared library 'avcodec-55.dll' (error 126: the specified module could not be found.)
16:19:20: Loading avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
16:19:20: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 0: the operation completed successfully.)
16:19:20: Actual avutil path
16:19:20: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 0: the operation completed successfully.)
16:19:20: Actual avcodec path
16:19:20: Importing symbols...
16:19:20: Error: Failed to load symbol av_init_packet
16:19:20: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
16:19:20: Checking that '' is in PATH...
16:19:20: Checking for monolithic avformat from 'avformat-55.dll'.
16:19:20: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
16:19:20: Loading avutil from ''.
16:19:20: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
16:19:20: Loading avcodec from ''.
16:19:20: Loading avformat from 'avformat-55.dll'.
16:19:20: Error: Failed to load FFmpeg libraries.
16:19:20: Error: Failed to find compatible FFmpeg libraries.
log attmpting 64bit ffmpeg avformat-57.dll (note, it powered up looking in the win32 folder; then I pointed it to win64 later):
Possible key lines:
16:20:26: User-specified FFmpeg file exists. Success.
16:20:27: Error: Failed to load shared library ‘E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin\avformat-57.dll’ (error 193: unknown error c1)
16:19:55: Audacity 2.1.3
16:19:55: Trying to load FFmpeg libraries...
[color=#0000FF]16:19:55: mLibAVFormatPath ('E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll') is not empty. Loading from it.[/color]
16:19:55: Looking up PATH environment variable...
16:19:55: PATH = 'C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Chocolatey_nonadmin\bin;'
16:19:55: Checking that 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin' is in PATH...
16:19:55: Warning: FFmpeg directory 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin' is not in PATH.
16:19:55: Temporarily prepending ';E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin' to PATH...
16:19:55: Checking for monolithic avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
16:19:55: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: the specified procedure could not be found.)
16:19:55: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: the specified procedure could not be found.)
16:19:55: avformat not monolithic
16:19:55: Loading avutil from 'avutil-52.dll'.
16:19:55: Error: Failed to load shared library 'avutil-52.dll' (error 126: the specified module could not be found.)
16:19:55: Loading avcodec from 'avcodec-55.dll'.
16:19:55: Error: Failed to load shared library 'avcodec-55.dll' (error 126: the specified module could not be found.)
16:19:55: Loading avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
16:19:55: Returning PATH to previous setting...
16:19:55: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 0: the operation completed successfully.)
16:19:55: Actual avutil path
16:19:55: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 87: the parameter is incorrect.)
16:19:55: Actual avcodec path
16:19:55: Actual avformat path E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll
16:19:55: Importing symbols...
16:19:55: Error: Failed to load symbol av_init_packet
16:19:55: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
16:19:55: PATH = 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Chocolatey_nonadmin\bin'
16:19:55: Checking that '' is in PATH...
16:19:55: FFmpeg directory is in PATH.
16:19:55: Checking for monolithic avformat from 'avformat-55.dll'.
16:19:55: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
16:19:55: Loading avutil from ''.
16:19:55: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
16:19:55: Loading avcodec from ''.
16:19:55: Loading avformat from 'avformat-55.dll'.
16:19:55: Error: Failed to load FFmpeg libraries.
16:19:55: Error: Failed to find compatible FFmpeg libraries.
16:20:09: Attempting to load LAME from system search paths
16:20:09: Loading LAME from lame_enc.dll
16:20:09: Error: Failed to load shared library 'lame_enc.dll' (error 126: the specified module could not be found.)
16:20:09: load failed
16:20:09: Attempting to load LAME from builtin path
16:20:09: LAME registry key does not exist.
16:20:09: Library path is:
16:20:09: (Maybe) ask user for library
16:20:09: Failed to locate LAME library
16:20:11: Trying to load FFmpeg libraries...
16:20:11: mLibAVFormatPath ('E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll') is not empty. Loading from it.
16:20:11: Looking up PATH environment variable...
16:20:11: PATH = 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Chocolatey_nonadmin\bin'
16:20:11: Checking that 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin' is in PATH...
16:20:11: FFmpeg directory is in PATH.
16:20:11: Checking for monolithic avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
16:20:11: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: the specified procedure could not be found.)
16:20:11: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: the specified procedure could not be found.)
16:20:11: avformat not monolithic
16:20:11: Loading avutil from 'avutil-52.dll'.
16:20:11: Error: Failed to load shared library 'avutil-52.dll' (error 126: the specified module could not be found.)
16:20:11: Loading avcodec from 'avcodec-55.dll'.
16:20:11: Error: Failed to load shared library 'avcodec-55.dll' (error 126: the specified module could not be found.)
16:20:11: Loading avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll'.
16:20:11: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 0: the operation completed successfully.)
16:20:11: Actual avutil path
16:20:11: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 0: the operation completed successfully.)
16:20:11: Actual avcodec path
16:20:11: Actual avformat path E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin\avformat-57.dll
16:20:11: Importing symbols...
16:20:11: Error: Failed to load symbol av_init_packet
16:20:11: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
16:20:11: Checking that '' is in PATH...
16:20:11: Checking for monolithic avformat from 'avformat-55.dll'.
16:20:11: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
16:20:11: Loading avutil from ''.
16:20:11: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
16:20:11: Loading avcodec from ''.
16:20:11: Loading avformat from 'avformat-55.dll'.
16:20:11: Error: Failed to load FFmpeg libraries.
16:20:11: Error: Failed to find compatible FFmpeg libraries.
16:20:11: Looking for FFmpeg libraries...
16:20:26: User-specified path = 'E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin\avformat-57.dll'
16:20:27: Trying to load FFmpeg libraries...
16:20:27: mLibAVFormatPath ('E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin\avformat-57.dll') is not empty. Loading from it.
16:20:27: Looking up PATH environment variable...
16:20:27: PATH = 'E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Chocolatey_nonadmin\bin'
16:20:27: Checking that 'E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin' is in PATH...
16:20:27: Warning: FFmpeg directory 'E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin' is not in PATH.
16:20:27: Temporarily prepending ';E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin' to PATH...
16:20:27: Checking for monolithic avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin\avformat-57.dll'.
16:20:27: Error: Failed to load shared library 'E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin\avformat-57.dll' (error 193: unknown error c1)
16:20:27: Loading avutil from ''.
16:20:27: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
16:20:27: Loading avcodec from ''.
16:20:27: Loading avformat from 'E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin\avformat-57.dll'.
16:20:27: Returning PATH to previous setting...
16:20:27: Error: Failed to load FFmpeg libraries.
16:20:27: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
16:20:27: PATH = 'E:\portables\ffmpeg\ffmpeg-3.3.2-win64-shared\bin;E:\portables\ffmpeg\ffmpeg-3.3.2-win32-shared\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\'
16:20:27: Checking that '' is in PATH...
16:20:27: FFmpeg directory is in PATH.
16:20:27: Checking for monolithic avformat from 'avformat-55.dll'.
16:20:27: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
16:20:27: Loading avformat from 'avformat-55.dll'.
16:20:27: Error: Failed to find compatible FFmpeg libraries.
If you mean the PortableApps version of Audacity, that is not our product and we are not able to offer support because we don’t know what modifications they have made. Contact PortableApps for support.
On the other hand, you can download the ZIP version of Audacity via the Audacity website (Audacity ® | Download for Windows) and use that as a portable version by creating a “Portable Settings” folder in the same location as the audacity.exe file (see: Missing features - Audacity Support)
For the official version of Audacity, see here for information about supported versions of FFmpeg: FAQ:Installation, Startup and Plugins - Audacity Manual
If you use the Audacity ZIP file supplied by us, it supports maximum of FFmpeg 2.3.x for loading through Libraries Preferences. Use our recommended FFmpeg installer: http://manual.audacityteam.org/man/installing_and_updating_audacity_on_windows.html#winff.
Alternatively you can export (not import) using arbitrary versions of ffmpeg.exe using Audacity’s command-line exporter.
Yeah, I read that, just didnt think it could be correct.
To be explicit:
The manual Installing and updating Audacity on Windows - Audacity Manual section “Installing the FFmpeg Import/Export Library on Windows”
Says to
Go to the external download page
Left-click > this link> , do not right-click.
“this link” is http://lame.buanzo.org/#lamewindl
The FFMPEG section of that page a little lower down says
RECOMMENDED ZIP OPTION: > ffmpeg-win-2.2.2.zip
The zip file is http://lame3.buanzo.com.ar/ffmpeg-win-2.2.2.zip
That all seemed obscure to me. But if it’s the recommend way, I trust y’all.
BTW I edited the OP. I am trying to import a .webm file audio/webm downloaded from youtube.
Then why not simply install FFmpeg 2.2.2 per our instructions? The FFmpeg 2.2.2 we “recommend” on the Buanzo page supports WebM. The WebM container format uses the VP8 video format with Vorbis or Opus audio and FFmpeg 2.2.2 includes support for Opus as well as Vorbis audio.
If your desired WebM file does not import into Audacity using FFmpeg 2.2.2, shows us the output of Help > Show Log… and the output of MediaInfo. You can download “MediaInfo” from MediaInfo - Download MediaInfo for Microsoft Windows. Get the version without installer, because the installer may have malware or adware.
