This has been a problem for quite a while for me and it’s gotten to be a real pain. Audacity recording just outright freezes for almost a minute at a time at points.
Notice how the audio position in the bottom right is still going/ahead of what’s on the time bar/recording? That happens all the time and I have no idea how to fix it. Ultimately it will resume recording (albeit behind the audio timer), and anything I tried to record during that dead time just doesn’t register at all. Need some serious help on this.
Of course you can ignore my suggestion and ask your friends instead. You could also try a higher Audio to Buffer in Audacity’s Recording Preferences. I won’t be helping you further.
Except I was just saying that I have doubts that’s the reason when I have friends with the exact same set up and it works fine, I don’t see how that’s reason to pull something like that kind of response.
But fine then, guess I’m moving onto something else to record on.
I’m not ignoring Gale, I’m simply asking for clarification on why you think that’s the issue when I have evidence to think otherwise. I don’t just blindly follow directions.
Cold Boot gives you a brand new kernel session. Otherwise when you shut down normally, you go on and on reusing the old kernel session. Assuming you connect this headset by USB cable, this is very bad for USB recording devices. There is no way doing a cold boot is harmful, exactly the opposite.
