Batch Normalisation
Windows 7 Professional
Audacity 2.1.3
I have thousands of MP3 files… from various sources over many years.
If I had to normalise each one individually, then export to a new folder, it would take me a very, very, long time.
Is there a way to get Audacity to “Batch Normalise” them all to the same level. Ideally putting the normalised tracks into a new folder (just in case anything goes wrong in the process).
The process would also need to dig into Artist->Album subfolders to get to most of the tracks.
I’ve got the idea - chains
But don’t think I’ll be able to include multiple files from sub-folders
You won’t. But you are using the wrong tool, because you will degrade the MP3 files when you re-encode them in Audacity. mp3DirectCut will normalize the files for you without re-encoding.
Note that normalizing won’t make them sound equally loud.
If you want them to sound equally loud, try [u]MP3Gain[/u] or use a player that supports [u]ReplayGain[/u], or if you have Apple hardware or ITunes, switch-on Sound Check.
MP3Gain and ReplayGain can batch process all of your files, or there is an AlbumGain mode where one album/folder is processed at a time to volume-match the level of the album as a whole while maintaining the relative loudness difference between quiet and loud songs on an album,
Note that all of these loudness matching techniques will make many/most songs quieter. That’s because many quiet-sounding songs are already normalized (maximized), so the only way to match volumes is is by setting a lower target level, making the loudest songs quieter.
