Hello,
at the end of each word my voice does a robot’s noice… how i can erase this ?
( i am french so it’s normal if you find some mistakes )
cordially,
batax19
Hello,
cordially,
batax19
You can get that if you use too much noise reduction or your Windows machine tries to help you get rid of background noise.
Post a raw voice sample on the forum. Don’t fix it or apply any effects.
