I can't run Gsnap VST effect on my windows 10 Audacity
Permanent link to this post Posted by Giovani » Thu Apr 20, 2017 6:59 am
Hi!
I have a new version of Audacity. I can't curently run the autotune G-snap vst plugin.
It just says to me, that attempting of load following effect failed.
I have tried also 32-bit version, also My windows is 64-bit. But, I can't find a select scale button here.
Also, I am blind, but something was changed on It?
Thank You!
Marco
Giovani
Re: I can't run Gsnap VST effect on my windows 10 Audacity
Permanent link to this post Posted by Gale Andrews » Thu Apr 20, 2017 1:36 pm
Audacity will only run 32-bit effects on Windows.
If the message said that default settings will be used, that message should only occur once.
GSnap does not work properly in Audacity because Audacity does not support MIDI tuning. Here is an alternative: Autotalent for Windows (VST) http://www.vst4free.com/free_vst.php?plugin=Autotalent&id=842. It might be better for your screen reader too, given it only has a text-based interface.
If you still prefer GSnap, navigate to the "Manage Presets and Options" button, choose "Options", uncheck the option for "Enable graphical interface" then restart the effect.
The best list for getting help is Audacity4Blind: http://wiki.audacityteam.org/wiki/Audacity_for_blind_users#docs.
Permanent link to this post Posted by Giovani » Thu Apr 20, 2017 2:19 pm
Thank You!
Also, I know for example Kerovee or Rovee, this is another alternative and ofcourse, Autotalent is pretty fun, but sometimes It made a delay.
Giovani
Permanent link to this post Posted by Giovani » Fri May 12, 2017 3:29 pm
Also, another excellent alternative too is Kerovee from g202kg.
Giovani
Return to Windows
Who is online
Users browsing this forum: No registered users and 11 guests
