Cannot time shift single audio track [SOLVED]
Permanent link to this post Posted by Patrick elwira ahmed » Wed Apr 19, 2017 10:59 pm
Hi guys,
I am using audacity 2.1.3 on windows 7, i am not able to time shift a single audio track without every other track moving along with it, ive tired everything that i found online, i never had this problem before, also i want to mention that i just downloaded audacity 2.1.3 on my other laptop just to see if it would work, and it did, so i'm just really confused as to why such a simple thing isn't working on this computer.
any ideas?
Patrick
Operating System: Windows 7
Re: Cannot time shift single audio track
Permanent link to this post Posted by steve » Wed Apr 19, 2017 11:47 pm
Check that you've not accidentally enabled "Sync-Lock" (see: http://manual.audacityteam.org/man/sync ... roups.html)
Re: Cannot time shift single audio track [SOLVED]
Permanent link to this post Posted by Patrick elwira ahmed » Thu Apr 20, 2017 9:35 am
that has solved the problem, what a simple solution.
thanks a lot man, i appreciate it. :D
patrick
Return to Windows
Who is online
Users browsing this forum: No registered users and 12 guests
