Latency Error Correction
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by S Doug Peren » Tue Apr 18, 2017 4:33 pm
Im using Audacity version win 2.1.0.exe with Windows 7. I can't record because the Latency Error Correction prevents me from doing so. I was able to correct the problem by reloading Audacity, but now any version I try has the latency problem. What can I do?
S Doug Peren
Re: Latency Error Correction
Permanent link to this post Posted by kozikowski » Tue Apr 18, 2017 4:55 pm
Which latency problem? You can't listen to the computer while you record. Machine latency will just kill you with delay and echo. It is recommended you listen to the microphone or interface device.
Overdubbing latency, the ability to record several different instruments one on top of the other is easily correctable with the overdubbing latency adjustment process.
http://manual.audacityteam.org/man/tuto ... rdubs.html
Permanent link to this post Posted by Gale Andrews » Wed Apr 19, 2017 3:01 pm
S Doug Peren wrote:Im using Audacity version win 2.1.0.exe with Windows 7. I can't record because the Latency Error Correction prevents me from doing so. I was able to correct the problem by reloading Audacity, but now any version I try has the latency problem. What can I do?
Exactly what are you recording, using what recording device (make and model number), and how does that recording device connect to the computer?
Is your recording stalling so that the red recording cursor does not move? If yes and if the recording device connects by a USB cable, reboot the computer.
If that is not the problem, Edit > Preferences..., Recording section and increase "Audio to buffer".
Permanent link to this post Posted by S Doug Peren » Sun Apr 23, 2017 6:37 pm
I found the answer in the Manual at Subject Index > Latency Test
S Doug Peren
Permanent link to this post Posted by tezhowes » Mon Dec 25, 2017 5:38 pm
Using version 2.2.1 and I solved my problem of getting the latency error that prevented recording a second track by going to Windows / Sound / Playback / Properties (I'm using a Tascam US-122 Mk II audio interface) and changing the sample rate / bit depth from the default of 16 bits / 48000 Hz to 16 bits / 44100 Hz to match the sample rate in Audacity. And ensured that overdub was checked and software playthrough was unchecked. :)
tezhowes
Return to Windows
Who is online
Users browsing this forum: Google [Bot], kozikowski and 8 guests
