Aud 2.1.3, Windows 10, can't play old files
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by obscurereference » Mon Apr 17, 2017 7:37 pm
I just used the installer to load 2.1.3. The old files I have are extremely distorted. I tried deleting and re-installing, no luck. Same thing if I record. Playback is just a bunch of buzzing.
obscurereference
Re: Aud 2.1.3, Windows 10, can't play old files
Permanent link to this post Posted by DVDdoug » Mon Apr 17, 2017 10:07 pm
Is there a particular format you're having trouble with? Are these Audacity AUP files, or WAV, etc.?
Can you play the files with other software (Windows Media Player, etc.)?
Are you saying it's distorted if you record something, and then play it back before saving/exporting?
If you record & export, can you play the files in Windows Media Player?
DVDdoug
Forum Crew
Permanent link to this post Posted by Gale Andrews » Tue Apr 18, 2017 2:19 pm
obscurereference wrote:I just used the installer to load 2.1.3. The old files I have are extremely distorted. I tried deleting and re-installing, no luck. Same thing if I record. Playback is just a bunch of buzzing.
Reinstalling Audacity does not change its settings at all unless you enable "Reset Preferences" half way through the installer.
To record, choose the device you recording from in Device Toolbar.
Have you installed the FFmpeg Import/Export Library? This lets you import many more file types into Audacity.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
