I’ve been having a problem lately when trying to record. After I’m done recording I remove the noise then normalize. Once normalized there is a very loud overwhelming static sound in the audio. I’ve tried everything to get rid of it. Using and MXL770 mic and a Behringer Uphorio UM2 interface. I’ve attached a video so you all can see and hear the issue. Thanks
which three-number Audacity do you have?
You’ve not given us much to go on, but my guess is that whatever it is that you are recording is probably too quiet, so that when it is normalized it is amplified a lot, and so causing the background hiss to become excessively loud. The solution would be to increase the signal level of the thing that you are recording.
Topics merged and duplicate post deleted.
