I like to use audicity program at school. But I need to convert the files into mp3. It was said to use LAME, but this doesn´t work with Windows 10.
Can you help me and recommend help for converting the files?
Thank you so much.
Thank you so much.
If this is on a school computer and you are a pupil at the school, then you may need to ask your teacher or IT staff to install “LAME for Audacity”. Download and installation instructions are available here: http://manual.audacityteam.org/man/faq_installation_and_plug_ins.html#lame If it’s your own computer, then those instructions are for you.
