Re: Problem about Recording calls in window 7
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by Gale Andrews » Fri Nov 11, 2016 12:38 pm
This post was in response to a now banned user who was posting questions copied from other users
Assuming these are VoIP calls like Skype then you won't easily be able to correct the volume imbalance and also both parties to the call will be mixed together instead of in separate channels.
Use a recording application meant for recording VoIP calls. If it's Skype try Pamela http://www.pamela.biz/ or MP3 Skype Recorder: http://voipcallrecording.com/.
Note that the current Audacity version is 2.1.2 which you can obtain from our site http://www.audacityteam.org/download/.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 9 guests
