Hi
Can you please help me by telling me where i can find the required DLL’s
When i look in the log under Help, Show Log i see the following errors -
20:25:43: Audacity 2.0.4
20:25:45: Trying to load FFmpeg libraries...
20:25:45: Trying to load FFmpeg libraries from system paths. File name is 'avformat-52.dll'.
20:25:45: Looking up PATH environment variable...
20:25:45: PATH = 'C:Program FilesPC Connectivity Solution;C:Program FilesNVIDIA CorporationPhysXCommon;C:Program FilesBorlandDelphi7Bin;C:Program FilesBorlandDelphi7ProjectsBpl;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program FilesMicrosoft SQL Server90Toolsbinn;C:Program FilesQuickTimeQTSystem;C:Program FilesSamsungSamsung PC Studio 3;C:Program FilesMicrosoft SQL Server100ToolsBinn;C:Program FilesMicrosoft SQL Server100DTSBinn;C:Program FilesWindows LiveShared;C:Program FilesCommon FilesAheadLib'
20:25:45: Checking that '' is in PATH...
20:25:45: FFmpeg directory is in PATH.
20:25:45: Checking for monolithic avformat from 'avformat-52.dll'.
20:25:45: Error: Failed to load shared library 'avformat-52.dll' (error 126: the specified module could not be found.)
20:25:45: Loading avutil from 'avutil-50.dll'.
20:25:45: Error: Failed to load shared library 'avutil-50.dll' (error 126: the specified module could not be found.)
20:25:45: Loading avcodec from 'avcodec-52.dll'.
20:25:45: Error: Failed to load shared library 'avcodec-52.dll' (error 126: the specified module could not be found.)
20:25:45: Loading avformat from 'avformat-52.dll'.
20:25:45: Error: Failed to load FFmpeg libraries.
20:25:45: Error: Failed to find compatible FFmpeg libraries.
Thanks a stack
Christopher
