Audacity software will not work with Digitech Audio model G
Permanent link to this post Posted by coggie » Mon Aug 26, 2013 8:48 am
I have Windows 7 on a 64 bit operating system. Installed Audacity 2.0.3 plus the Lame plug-in. Supposed to work with Digitech Audio USB cassette player Model No. 4140. No way can I get it to work. The cassette player works OK with Roxio NXT. Won't work with Audacity. Can anybody help as I like the look of the Audacity interface better than the Roxio.
coggie
Re: Audacity software will not work with Digitech Audio mode
Permanent link to this post Posted by steve » Mon Aug 26, 2013 9:44 am
Ensure that the Digitech Audio USB cassette player is connected to the computer before you open Audacity (close and restart Audacity if necessary).
Ensure that the USB cassette player is selected as the recording input in the device toolbar. Your usual sound card should be selected as the playback output device.
Return to Windows
Who is online
Users browsing this forum: No registered users and 14 guests
