No Waveform, No Sound
Help for all users of Audacity 2.x on Windows.
This forum is for Audacity 2.x on Windows.
For all help enquiries, please state which version of Windows you are using and whether you installed Audacity from the .exe installer or obtained the zip.
Users of Audacity 1.3.x are encouraged to update by downloading the latest version from here.
The old forum for Audacity 1.3.x on Windows is HERE.
Permanent link to this post Posted by wittenbergdoor » Thu Nov 15, 2012 8:35 pm
Hi,
I am running Audacity 2.02 on a Windows 7 Professional 64-bit operating system, and I am having the following problem, which started about a week ago for me.
I use Audacity to edit audio files (aiff and aiff converted to MP3) that I record myself on my iPhone. Usually, I just drag the file into audacity and rock-n-roll. Now, however, I drag them in or import them (file > import > audio), and when it imports them, there is no waveform, just a straight line, and no sound when I play them, although the length of the playback section is consistent with the length of the audio file. This only happens when I select "make a copy of the files before editing." If I select "read the files directly from the original," then the audio does play back, but instead of seeing a waveform, I see a series of diagonal blue lines, which makes editing much more difficult, if not near-impossible to get right.
Any input on this would be greatly appreciated. I don't know this program very well, so if you could be clear and specific in your suggestions, that would help.
Thanks so much,
Doug
wittenbergdoor
Re: No Waveform, No Sound
Permanent link to this post Posted by steve » Thu Nov 15, 2012 8:47 pm
wittenbergdoor wrote: I see a series of diagonal blue lines, which makes editing much more difficult, if not near-impossible to get right.
The diagonal lines are normal when importing uncompressed audio with "read the files directly from the original" selected, but after a few moments those lines should start to disappear and be replaced by the actual waveform. I presume that is not happening even if you leave the computer for several minutes?
Do you have any old audio files that previously worked with Audacity? If you have, do they still work?
Senior Forum Staff
Permanent link to this post Posted by wittenbergdoor » Fri Nov 16, 2012 12:55 am
Thanks for responding.
No, the diagonal lines do not go away, no longer how long I leave it for.
And I tried importing old files which I edited a few months ago, and the same thing happens--no waveform, no sound.
Any ideas?
wittenbergdoor
Permanent link to this post Posted by Gale Andrews » Fri Nov 16, 2012 6:49 am
Have you changed your Audacity temporary directory to somewhere you don't have permission to write to, or to a drive that is failing? Please check at Edit > Preferences: Directories.
If changing the temporary directory does not help, can you please (after importing a file) click Help > Show Log... then Log > Save... and attach the log here (see viewtopic.php?f=49&t=64936 for how to attach files).
Permanent link to this post Posted by wittenbergdoor » Fri Nov 16, 2012 1:53 pm
That did it!
I changed the temp directory to a folder I created on my desktop, and presto, I've got waveforms and sound. Thank you so much for your help. I really appreciate it, although I don't know why that problem happened in the first place. Hmmmmm--I did install some new antivirus software. Maybe that was it. Thanks again, though, and God bless.
wittenbergdoor
Return to Windows
Who is online
Users browsing this forum: No registered users and 4 guests
