Audio Splitter Recommendations for Recording
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by dcara » Fri Aug 17, 2012 3:02 pm
I want to record what is coming out my laptop speakers and also add additional sound. So I figured what I need to do is get 2 Y cables with a 3.5mm plug and 2 jacks plus one 3.5mm cable with plugs on both ends. Then connect like shown below
3.5 mm audio out jack-----------y------O-jack to stereio speakers
O jack
| plug to plug cable
O jack
3.5 mm Sterio Mic input--------Y-------O stereio input jack
Questions
1) Will this work
2) How to handle feed back issues
3) Can I use this approach to add multiple tracks and then select which tracks get played back to which speaker channel?
dcara
Re: Audio Splitter Recommendations for Recording
Permanent link to this post Posted by kozikowski » Fri Aug 17, 2012 6:08 pm
Probably the first problem is going to be the Mic-In and Line-Out are different.
Stereo Line-Out is powerful, high-level, and is loud enough to drive headphones. Mic-In is expecting a very wimpy, delicate, mono microphone signal. These two connections are used for video/audio conferencing. Mic-In is very likely to overload and sound crunchy if you cross them like that.
The first one of those is Recording Sound On The Computer.
The second part is called Overdubbing or Sound-On-Sound. We wrote instructions how to do both.
http://manual.audacityteam.org/o/man/tu ... puter.html
http://manual.audacityteam.org/o/man/tu ... rdubs.html
Permanent link to this post Posted by dcara » Mon Aug 20, 2012 9:29 pm
Thanks - That seems to be working
dcara
Return to Windows
Who is online
Users browsing this forum: No registered users and 8 guests
