Hi there,
one awesome conveniency of 1.3.x that 2.0.x doesn’t seem to have (unless I’m doing something wrong) is that with 1.3, I can right-click an audio file (be it .mp3, .wav, .flac, whatever), and in the “open with” drop-down, I can select Audacity.exe, importing said audio track into a new Audacity 1.3 project doing that. If I try to do the same with the Audacity.exe of version 2.0, Windows will ignore that I selected Audacity.exe, disabling me from importing the right-clicked track into Audacity 2.0. (This problem persists independent of whether or not an older version of Audacity is installed on my PC simultaneously to 2.0.)
I use Windows 7 64-bit and install Audacity from the .exe installers. Any help would be greatly appreciated, as I usually open audio tracks into Audacity with this method probably more than 50 % of the time. So far the solution is to just keep a copy of 1.3 on the PC for that purpose, as the differences between 1.3 and 2.0 aren’t annoyably vast.
Thanks in advance.
- Shake
