cheers!
I have a Audicity 2.0 on windows 7.
I would like to know how can I create separate tracks from a recording (LP), which has an uninterrupted flow between the songs.
Have I made myself clear? Becuase my english is not too good.
many thanks
You can capture one whole side of a record and then mark the songs with the Label Tool. Then you Export Multiple and Audacity will create separate music files, one per label. Then you copy all those files into a Music CD burning program and make a CD. Is that it?
http://manual.audacityteam.org/help/manual/man/splitting_a_recording_into_separate_tracks.html
