I need some help! If it's possible.
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by DarfBobbyJim » Sun Mar 18, 2012 3:30 am
help.aup
(2.24 KiB) Downloaded 72 times
Listen to this attachment. It's the begining of my song. You can hear a loud buzzing sound, and this bit is quiet compared to the rest of my song so I need to amplify it but when I do the buzzing get's louder. Is it possible to reduce this? Noise Removal isn't working D:
DarfBobbyJim
Re: I need some help! If it's possible.
Permanent link to this post Posted by kozikowski » Sun Mar 18, 2012 5:31 am
That's an Audacity Project Manager file, not a sound file.
We may not need it. What are you using for a microphone and how is it connected to your computer? What kind of computer is it?
You probably can't fix this in post production. Microphone buzz is difficult to remove.
Return to Windows
Who is online
Users browsing this forum: No registered users and 9 guests
