Upgrading to 2.0
  • Please state which version of Windows you are using, the exact three-section version of Audacity from Help > About Audacity and whether you obtained the .exe installer or the zip.
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Upgrading to 2.0
Permanent link to this post Posted by folmonty » Sat Mar 17, 2012 2:35 pm
I'm a new convert from using DAK and really like Audacity. My hats off to the development team for such a flexible and functional audio tool as this! A simple question I couldn't find in the FAQ or user manual.
Already have Beta version 1.3 with LAME installed. Before upgrading to 2.0 is it necessary to uninstall previous versions? Does LAME need to be reinstalled also? I'm running 64bit Win7.
Thanks very much!
Monty
folmonty
Re: Upgrading to 2.0
Permanent link to this post Posted by steve » Sat Mar 17, 2012 4:46 pm
It's probably best to uninstall Audacity 1.3.x beta first so as to avoid complications with file associations.
If you have a reasonably recent version of Lame that works with Audacity 1.3.x then Audacity 2.0 should pick it up automatically (so leave LAME installed and when you have installed Audacity 2.0 check that MP3 export works OK).
Permanent link to this post Posted by PGA » Sat Mar 17, 2012 5:06 pm
I have successfully installed v2.0 alongside v1.3.14 without any problems. As far as I recall, the file associations moved over to v2.0 automatically. I have discovered that, if I really want to, I can switch them to and fro using a right-click on an .aup file then choosing "Open With... Choose default program...". This is on a Win 7 Home Premium 64-bit SP1 system. I didn't need to re-install either LAME or FFmpeg - these were picked up automatically by v2.0.
PGA
Permanent link to this post Posted by steve » Sat Mar 17, 2012 5:20 pm
PGA wrote:As far as I recall, the file associations moved over to v2.0 automatically.
I think that is what should happen but Windows can misbehave and get confused, so uninstalling 1.3.x first is the safer option.
PGA wrote: I didn't need to re-install either LAME or FFmpeg - these were picked up automatically by v2.0.
That seems to work reliably :)
Permanent link to this post Posted by folmonty » Sat Mar 17, 2012 6:53 pm
Uninstalled the old and installed the new without any trouble. Updated to LAME 3.99.3 from 3.98.3 and added the plug-in file as well. Talk about effects choices! Works like a charm.
Great work! Using Audacity is truly a joy in function and flexibility.
Thanks again!
Monty
Danville, CA
folmonty
Permanent link to this post Posted by Gale Andrews » Mon Mar 19, 2012 2:52 am
steve wrote:It's probably best to uninstall Audacity 1.3.x beta first so as to avoid complications with file associations.
If there are existing Audacity 1.3.x associations with audio files, associations for 2.0 won't be creatable with "Open with" whether you uninstall 1.3.x or leave it in situ unless you:
  • run CCleaner to remove the old association
  • rename the 2.0.0 audacity.exe.
See viewtopic.php?f=46&t=64286&start=10#p174205 .
Permanent link to this post Posted by PGA » Mon Mar 19, 2012 8:04 am
@Gale,
That's not true as my posts in that topic make clear. I have both v2.0 and v1.3.14 installed alongside each other and can use "Open with" to change the file association from one to the other as and when I choose (not that I actually want to). Like the original poster, I'm also on a Win 7 64-bit system so would be interested to hear whether this is true on his/her system.
PGA
Permanent link to this post Posted by Gale Andrews » Tue Mar 20, 2012 4:08 am
PGA wrote:@Gale,
It's true for most people - it's getting complained about frequently now 2.0.0 is out. I'm aware it works for you - but since no-one knows why, we can't give them your solution. :)
Permanent link to this post Posted by PGA » Tue Mar 20, 2012 7:09 am
Gale Andrews wrote:I'm aware it works for you - but since no-one knows why, we can't give them your solution.
If it will increase understanding, I'd be happy to take screen grabs of parts of my Registry - if someone could tell me which bits to grab :D
PGA
Permanent link to this post Posted by steve » Tue Mar 20, 2012 7:53 am
@PGA, did you ever have Audacity 1.2.x installed on that machine?
Could you remind me which version of Windows you use.
Next
Return to Windows
Who is online
Users browsing this forum: No registered users and 7 guests
