Can't control input volume
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by fdlevy » Sat Mar 17, 2012 1:06 pm
After successfully digitizing some 1500 LP records with an early version of Audacity on my old Windows XP computer, I have acquired a DEll XPS 8300 with Windows 7 Ultimate and have downloaded Audacity 2.0 to convert the rest of my collection. But, in order to get the input volume (my recording source is an ION USB turntable) almost within the recordable range, I have to turn my computer volume control and the Audacity volume control bar practically down to zero. My sound card is a Sound Blaster X-fi Extreme Audio. Can you tell me my problem and what I can do about it?
fdlevy
Re: Can't control input volume
Permanent link to this post Posted by kozikowski » Sat Mar 17, 2012 3:05 pm
How did you connect the ION turntable to your computer? You should only have one USB connection, not RCA cables and adapters, and you should be recording from the USB Audio Device, not Mix-Out or WAV-Out. Set this in the Audacity Device Toolbar...
http://manual.audacityteam.org/man/Device_Toolbar
Or you may need to go into the Windows Control Panels and set it there.
Permanent link to this post Posted by fdlevy » Sat Mar 17, 2012 4:08 pm
Thanks much for the quick reply! Actually I found the solution going a dozen or so pages deeper than I had before into the Forum archive, and with the advice there discovered the well-hidden volume control at the rear bottom of the Ion TT itself.
fdlevy
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 18 guests
