LAME isn't working
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
LAME isn't working
Permanent link to this post Posted by cutiebabygirl8 » Thu Mar 15, 2012 8:52 pm
I have the Autacity 2.0 for windows/vista. I recorded a file and wanted to turn it into an mp3. (By the way, I've never used Autacity or LAME before.) I figured out that LAME can do that. I downloaded it several times, but after I set up, hit finish, it says you've successfully set up. It just closes and doesn't open. It just keeps repeating this process. I tried to get the file onto another computer, but it wouldn't transfer. I tried attaching it by email onto the other computer, to see is LAME worked in that computer. What should I do? IT IS URGENT! Please help. Thank you!
cutiebabygirl8
Re: LAME isn't working
Permanent link to this post Posted by kozikowski » Thu Mar 15, 2012 9:38 pm
Lame doesn't "do" anything. It loads instructions behind the curtains so Audacity knows how to make MP3 files the next time it opens. Did you restart Audacity?
File > Export > MP3 > Filename > Save
Permanent link to this post Posted by cutiebabygirl8 » Thu Mar 15, 2012 10:14 pm
When i go to file then export, i save it, i even change the type to mp3 file, but when i open it, it talkes me to my aup file.
cutiebabygirl8
Permanent link to this post Posted by kozikowski » Thu Mar 15, 2012 11:37 pm
Change the export filename.
MyMusic > MyMusic2. Don't add file extensions. Audacity will do that.
If you start having troubles with Windows, sometimes it's valuable to force it to show you "real" filenames and not the Windows' version.
-- Hidden File Extensions
-- Start > My Computer > Tools > Folder Options > View > [ ] Hide Extensions for Known File Types (deselect)
-- Apply (to this folder) or Apply to All Folders
-- OK
Permanent link to this post Posted by cutiebabygirl8 » Fri Mar 16, 2012 12:47 am
I got it, thank you so much.
cutiebabygirl8
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 22 guests
