[Solved] Stereo to mono - keep only left channel
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by Sprinterdriver » Wed Mar 14, 2012 11:54 pm
Hi.
I guess the subject covers the problem. I want to make a mono sound from a stereo wave file. But I only want to save the sound from left channel. Any sound from right channel should be removed.
Thanks
Last edited by Sprinterdriver on Thu Mar 15, 2012 10:11 pm, edited 1 time in total.
Sprinterdriver
Re: Stereo to mono - keep only left channel
Permanent link to this post Posted by billw58 » Thu Mar 15, 2012 12:23 am
http://manual.audacityteam.org/man/Track_Drop-Down_Menu
Select "Split Stereo to Mono" from the Track Drop-down Menu, then delete the lower of the two resulting mono tracks.
-- Bill
billw58
Permanent link to this post Posted by Sprinterdriver » Thu Mar 15, 2012 10:10 pm
billw58 wrote:http://manual.audacityteam.org/man/Track_Drop-Down_Menu
-- Bill
Thank you :D
Can't imagine I've spend that long time fiddling in the menus, and it's that simple :oops: :mrgreen:
Sprinterdriver
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 12 guests
