Record from Wave and Microphone
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by Paranoia » Fri Feb 03, 2012 11:55 pm
Hello, in Audacity I can select "Record Input" as Wave, Microphone, Stereo Mix, etc., but how I can select Wave and Microphone simultaneously?
Paranoia
Re: Record from Wave and Microphone
Permanent link to this post Posted by kozikowski » Sat Feb 04, 2012 12:06 am
You might be able to do that with the Mix-Out device.
-- Record Internet
http://wiki.audacityteam.org/wiki/Recording_audio_playing_on_the_computer
http://wiki.audacityteam.org/wiki/Mixer_Toolbar_Issues#Using_the_Control_Panel
I think this will let you bring up two sound devices at once. This is usually used to record the internet, but it's pretty common that sometimes people get stuck with two or more things playing at once.
Return to Windows
Who is online
Users browsing this forum: Google [Bot] and 8 guests
