Isochronic Modulator Plug-in
Archive of Nyquist Plug-ins.
Many of the plug-ins here will be available on the Audacity Wiki.
This Forum is an archive of old topics concerning Nyquist plug-ins.
Feedback and questions relating to topics may be posted, but please
DO NOT POST NEW TOPICS HERE.
New plug-ins may be posted on the New Plug-Ins board.
Other posts relating to Nyquist should be posted to the main Nyquist board.
The main repository for Audacity/Nyquist Plug-ins is on the Audacity Wiki.
Permanent link to this post Posted by steve » Fri Sep 10, 2010 8:10 pm
Current download on Wiki Download Nyquist Plug-ins page:
http://wiki.audacityteam.org/wiki/Nyquist_Effect_Plug-ins#Isochronic_modulator
In response to these posts:
viewtopic.php?f=39&t=38692&p=102225#p102225
viewtopic.php?f=39&t=39481&p=102423#p102416
The easiest solution would be to modify the tremolo code so that the pulses fade in/out.
I've modified the Variable Tremolo effect so that the pulses are adjustable.
To save space in the interface and simplify the code I have taken out the other waveform options.
The "Pulse Width" control allows you to set how long each pulse will be. Higher values will make the sound "on" for longer. Lower values for shorter pulses. At 50% the sound will be on for 50% of the time.
The "Fade Time" control may be increased for a more gradual fade in/out of the pulses. At 0% there will be no fade. At 100% the fade in/out times will be half of the pulse width.
If you want to change the default values, open the isomod.ny file in a text editor and change the numbers shown below, then save.
;control pw "Pulse Width [50%=Square]" real "%" 40 0 100
;control ft "Fade Time" real "%" 15 0 100
;control startf "Initial Modulation Frequency" real "Hz" 7 1 20
;control endf "Final Modulation Frequency" real "Hz" 2 1 20
;control starta "Initial Modulation Depth" int "%" 100 0 100
;control enda "Final Modulation Depth" int "%" 100 0 100
I've renamed this plug-in "IsoMod..." (Isochronic Modulator).
This version is also compatible with Audacity 1.2.6
Reason: add Wiki link
Re: Isochronic Modulator Plug-in
Permanent link to this post Posted by GendeDios » Sat Sep 11, 2010 10:46 pm
you've simplified my life a lot. Thanks.
GendeDios
Permanent link to this post Posted by steve » Sun Sep 12, 2010 12:53 am
You're welcome. It was an interesting project.
Permanent link to this post Posted by purefusion » Mon Sep 27, 2010 3:47 pm
Steve, you are awesome! This will be a time-saver indeed (and will help overcome numerous of Audacities editing flaws/imperfections). I've been doing this the hard way till now, which doesn't support isochronic ramping anyway... something I really wanted. But luckily you've saved the day (after I decided to Google 'Audacity isochronic plugin') ...and what damned good timing too! I had just thought about learning how to make plugins just to do this, but that's not something I really have time for anyway.
So from the bottom of my heart, thanks a million! I registered just to say that, too... ;)
Cheers!
purefusion
Permanent link to this post Posted by steve » Mon Sep 27, 2010 7:03 pm
You're welcome. Thanks for the feedback.
Permanent link to this post Posted by mmozaffa » Mon Oct 04, 2010 1:10 am
Sorry...
I'm a bit of a novice. I downloaded the attachment but have no idea how to open it within Audacity so that I can use the plug-in.
Mind giving me a quick tutorial?
Shane
mmozaffa
Permanent link to this post Posted by steve » Mon Oct 04, 2010 7:11 am
Plug-In Installation
To install new plug-ins, place them in the Plug-Ins folder inside the Audacity installation folder. On Windows computers, this is usually under "Program Files". On Mac OS X, it is usually under "Applications". Restart Audacity, then the Plug-ins will appear underneath the divider in the "Effect", "Generate" or "Analyze" menus.
http://audacityteam.org/download/plugins
Permanent link to this post Posted by tylertyler » Wed Jan 26, 2011 9:47 pm
Does this plugin work for the latest beta version for windows 7? I downloaded the plugin it and placed it into the plugins folder but I do not see it show up in any menu.
Thanks.
tylertyler
Permanent link to this post Posted by steve » Wed Jan 26, 2011 9:55 pm
Yes the plug-in works with Audacity 1.3.12 on all platforms.
Where exactly did yo put the isomod.ny file?
Did you restart Audacity?
Permanent link to this post Posted by tylertyler » Wed Jan 26, 2011 10:51 pm
I placed it here:
http://www.flickr.com/photos/[email protected]/5390910865/
And I did restart Audacity.
Tyler
tylertyler
Next
Return to Plug-in Archive
Who is online
