Recent version of Audacity have an option to add a time stamp to the name of a recorded track: http://manual.audacityteam.org/man/recording_preferences.html#Name_newly_recorded_tracks
The “Custom Track Name” in the Recording Preferences, automatically names new recorded tracks according to the other track name option, overriding the default “Audio Track” name.
By enabling “Custom Track Name” and “System Time”, the time (taken from to the computer’s system clock) is appended to the track name, in the form:
hh-mm-ss
This provides a way to work out the actual time than a recorded event actually happened. However, it is not very convenient to calculate this manually. For example, if a recording started at 03h 16m 23s, and an event occurs 2 hours, 52 minutes and 47 seconds into the recording, it’s not the easiest thing to see at a glance that the event occurred at 06h 09m 10s. This plug-in is designed to make that a whole lot easier.
To use this plug-in, ensure that the “Custom Track Name” and “System Time” options are enabled in Preferences.
If these options were not set before recording, or if the recording was made on a different device, then this plug-in can still be used so long as you know the start time of the recording - you just need to name the track with the start time, in the form hh-mm-ss appended.
Then, click on the track so that it is selected, and launch the plug-in from the Generate menu.
Settings:
Label every [nn] minutes after the hour: [0 to 59 (default 5)] Places labels at regular intervals this number of minutes past each hour.
Label every [nn] seconds after the hour: [0 to 59 (default 0)] Places labels at regular intervals this number of minutes past each hour. This is in addition to the number of minutes selected in the first control.
If both of the controls are set to zero, labels will be placed on the hour.
The plug-in also adds a label at the start and end of the track.
Each label text has the time in the format hh-mm-ss corresponding to the time at which that part of the audio track was recorded.
Example:
If a track has duration 59 minutes, and the track name has a time stamp at the end of 12-10-00 (10 minutes past midday), and the interval time set to 15 minutes, the labels will be:
12-10-00 (start of the track)
12-15-00 (first 15 minutes past the hour)
12-30-00
12-45-00
13-00-00 (24 hour clock)
13-09-00 (end of the track)
Installation instructions: http://wiki.audacityteam.org/wiki/Download_Nyquist_Plug-ins#install
Note that unlike most other labelling effects, this plug-in appears in the Generate menu.
Obsolete version:
record-time-labels.ny (6.25 KB)
New version: https://forum.audacityteam.org/download/file.php?id=18999
See next post for important information about this download.
