RMS Normalize
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Re: RMS Normalize
Permanent link to this post Posted by steve » Sun Dec 31, 2017 6:26 pm
Breakfast wrote:I started out trying to normalise to -18 but when that kept pushing everything into the clip-zone I kept knocking it down until I got to around -30, at which point it stopped boosting the loud parts up past zero.
You shouldn't need to go as low as -30 dB. Use a compressor and/or limiter and/or the envelope tool (http://manual.audacityteam.org/man/envelope_tool.html) to bring the audio to a more even level before you normalize the RMS.
Breakfast wrote:I thought once you hit clipping you were sonic toast?
It depends on when you hit clipping.
If you hit clipping during recording, then you are toast.
If you hit clipping on exporting, then you are toast (unless you export as 32-bit float, which is not generally recommended because few programs support 32-bit float audio)
If you hit clipping while working in Audacity, then you still have fresh bread (not toast), provided that your track is 32-bit float format (default).
One of the most useful features of 32-bit float format is that it doesn't stop at 0 dB, but can go on for hundreds of dB above the normal clipping level, so all you need to do to bring the audio back into the "valid" range (below 0 dB) is to apply the Amplify (or Normalize) effect with default settings.
As a demonstration:
1) Import some audio. Ensure that the track info panel says "32-bit float".
2) Apply the Amplify effect with default settings (the peak level is now 0 dB)
3) Apply the Amplify effect with +30 dB and the "allow clipping" option enabled. The peak level is now +30 dB and will sound very loud and distorted.
4) Apply the Amplify effect with default settings and "allow clipping" disabled, The peak level is now 0 dB and there is no damage.
Note, OGG and ALAC files will import as 16-bit and need to be changed manually to 32-bit float using the track drop-down menu (http://manual.audacityteam.org/man/audi ... tml#format)
Re: RMS Normalize
Permanent link to this post Posted by kozikowski » Sun Dec 31, 2017 7:10 pm
That's why it is recommended you announce live or present with occasional peaks at -10dB to -6dB, so you don't unintentionally overload before you ever have the chance to correct the errors.
Once you're inside Audacity, assuming you left everything alone, there is no overload. Apply the rumble filter to get rid of low frequency damage, apply RMS-Normalize to put the loudness where you want it and Limiter to gently squash the peaks. The goal of the suite is to achieve the desired technical values and still sound perfectly like you.
Also please note the odd limiting value of -3.5dB in the suite is designed so the show peaks are lower than -3dB after you export to MP3 . MP3 can create peak problems. It's good to allow for that any time you get into and out of MP3.
Which brings us to: Never do production in MP3. Do everything in Perfect quality WAV and convert to MP3 as a last step if you need to.
Given you have multiple performers, my opinion is you should try Chris's Compressor. The poster child for Chris is the Car Talk radio show where one performer presents loudly and has a nuclear laugh and the other mumbles in his beer. Pretty much your original complaint.
Re: RMS Normalize
Permanent link to this post Posted by kozikowski » Sun Dec 31, 2017 7:14 pm
Don't cut the end off the final edit until you run Chris. Leave the goodbys and post production trash on there to make Chris happy. After processing, then cut it off.
Re: RMS Normalize
Permanent link to this post Posted by kozikowski » Sun Dec 31, 2017 7:22 pm
I did a graphic of the compression effect. No Processing (raw capture), Default Chris at 0.5 and my version at 0.77. The waveforms get denser and the difference between high peaks and overall average starts going away.
Chris designed this processor so he could listen to opera in his noisy car. So everything between tutti orchestra and one violin in the south forty comes out about the same.
Re: RMS Normalize
Permanent link to this post Posted by Breakfast » Mon Jan 01, 2018 8:55 pm
steve wrote:If you hit clipping while working in Audacity, then you still have fresh bread (not toast), provided that your track is 32-bit float format (default).
This is enormous news for me, thank you so much. I had never made that connection. This changes a lot of things.
Have been trying out Chris' compressor too, and that seems to be really helpful. This thread is going to save me a lot of time and effort, I think, thank you all so much. :D
Breakfast
Operating System: Linux Mint
Re: RMS Normalize
Permanent link to this post Posted by kozikowski » Mon Jan 01, 2018 11:06 pm
It's possible to create special purpose sound files and other work for unusual jobs, but keep your eye surgically on the goal. If you ever expect anybody outside of your cohort to play the files, it's best if they're in a common format.
Time offsets can create problems, too. "Oh, wait. I think the only machine that can play my Frammis Format files is out in the garage."
RMS Normalize is what I needed for my PowerPoint-based workf
Permanent link to this post Posted by Graham Hannington » Fri Jan 19, 2018 7:28 am
Thank you for the RMS Normalize plug-in. It's exactly what I was looking for.
I use Audacity to record the voice over (narration) for videos that I produce in Microsoft PowerPoint. (It's okay, you can laugh ;) .)
I've used PowerPoint for many years to develop slides for "live" presentations. More recently, I've been using PowerPoint to produce videos. I export the presentations from PowerPoint, with timed effects and voice over, to MP4 format. So far, the slide transitions and animation effects in PowerPoint meet my needs. And I like the modularity of this approach. It's very easy to insert new "scenes" (slides) and combine or split videos.
I was already using Audacity to record the narration before I found the RMS Normalize plug-in, but I had a problem. My "modular" approach in PowerPoint meant exporting the narration for each slide to a separate file (I export to WAV, 32-bit float PCM). I was applying a chain that included Noise Reduction and Normalize; that is, peak normalization. There were jarring differences in loudness between audio clips.
The solution was to replace Normalize with RMS Normalize. Thanks again!
Graham Hannington
Re: RMS Normalize
Permanent link to this post Posted by steve » Fri Jan 19, 2018 5:01 pm
Graham Hannington wrote:for videos that I produce in Microsoft PowerPoint. (It's okay, you can laugh ;) .)
Reminds me of a (geek) video I saw recently: https://www.youtube.com/watch?time_cont ... Njxe8ShM-8
(and glad that you find the plug-in useful)
Re: RMS Normalize
Permanent link to this post Posted by tmiller5 » Sun Feb 04, 2018 2:50 pm
Are there any issues with this plug-in and Audacity 2.2.1? On my Mac I've copied the plugin to "Library--> Application Support --> audacity (and also in libs just for kicks)" and am trying to use the "Add/Remove Plug-ins" tool, but no luck.
Thanks for any assistance you may be able to offer.
tmiller5
Re: RMS Normalize
Permanent link to this post Posted by steve » Sun Feb 04, 2018 3:30 pm
tmiller5 wrote:Are there any issues with this plug-in and Audacity 2.2.1?
No. It is fully compatible with Audacity 2.2.1 (and 2.2.2 which is due to be released soon).
tmiller5 wrote:"Library--> Application Support --> audacity
There are two locations called "Library\Application Support\audacity"
You need the one that is in your home directory.
PreviousNext
Return to New Plug-Ins
Who is online
Users browsing this forum: No registered users and 2 guests
