pato wrote:the Effect drop-down menu doesn't show RMS Normalize or Limiter
Perhaps you're not looking low enough down the list of effects. By default it is below the dividing line.
pato wrote:When using my 15" laptop monitor only 6 of the 19 below-the-line effects appear
sertal wrote: where can I find the reference algorithm you used for this plugin?
This plug-in cleverly "cheats". It lets Audacity do the heavy lifting of calculating the initial RMS value,
then simply amplifies (multiplies the sample values by a constant value) as required.
sertal wrote:This is the missing part, for me: how to define the "constant value" to use? It is clearly related to the target RMS the user wants to achieve, but how?
Perhaps a little surprising, but it's pretty much the same as "peak normalization".
Just as amplifying a sound by +3 dB causes the peak level to increase by +3 dB, so it also causes the RMS level to increase by +3 dB.
Users browsing this forum: Bing [Bot] and 2 guests
