Pauken - add silence and repeat chunk
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Permanent link to this post Posted by olpa » Thu May 23, 2013 1:05 pm
Pauken adds silence and multiplies a selected fragment. It helps when you learn foreign languages by listening and repeating phrases after a speaker.
pauken.ny
(1010 Bytes) Downloaded 256 times
olpa
Re: Pauken - add silence and repeat chunk
Permanent link to this post Posted by steve » Thu May 23, 2013 2:00 pm
Thanks olpa. It works perfectly :)
What does the name mean?
Permanent link to this post Posted by Robert J. H. » Thu May 23, 2013 2:26 pm
If I can make a wild guess, it is a german slang Expression for "to learn labouriously and rather reluctantly" (e.g. "Pauker" is a teacher).
Robert J. H.
Operating System: Windows 7
Permanent link to this post Posted by olpa » Thu May 23, 2013 5:44 pm
It works perfectly
I'm glad to hear it, that the plugin works on other PCs too.
By the way, I use this tool for several months now. And I'm very satisfied. I speak better then several years ago.
The Robert's wild guess is correct. I am not a native german speaker, but hope that the word "pauken" reflects the goal of the plugin well.
olpa
Permanent link to this post Posted by Robert J. H. » Fri May 24, 2013 4:47 am
The Name fits perfectly, especially in Connection with vocabulary and word learning.
It is maybe connected to the german word for kettledrum. I imagine that the "Pauker" is the one who strikes the kettledrum on a galley to enforce the rowing of the slaves.
Another word would be "Büffeln".
We hardly ever use them in Switzerland, especially the former - rather a prussian expression.
Robert J. H.
Permanent link to this post Posted by pbassham » Fri Oct 10, 2014 9:40 am
This is good stuff.
I am wanting to make a version of files with silence at the beginning instead of the end. Would it be easy to add the option to add the silence at the beginning?
pbassham
Permanent link to this post Posted by steve » Fri Oct 10, 2014 2:05 pm
pbassham wrote:This is good stuff.
Try this (attached).
I've given it an English name ("Repeat with gaps...") as the vast majority of our users speak English.
If you want to change the default settings, open the file in a plain text editor (such as NotePad or NotePad++) and edit the lines that start with ";control". For example, to set the default number of repeats to 5, change:
Code: Select all
;control repeats "Number of repeats" int "" 3 1 20
to
Code: Select all
;control repeats "Number of repeats" int "" 5 1 20
The first number at the end of the line is the default value, the second number is the minimum value and the final number is the maximum value.
Numbers greater than the control range may be typed into the text boxes, but are not remembered the next time the effect is opened.
The "Sanitize" code prevents silly values being applied (thousands of repeats are likely to cause a crash).
RepeatWithGaps.ny
(1.03 KiB) Downloaded 128 times
Permanent link to this post Posted by pbassham » Fri Oct 10, 2014 2:59 pm
Fantastic! Thank you so much! My life just got much better. I really appreciate it.
pbassham
Permanent link to this post Posted by genaro » Tue Sep 19, 2017 1:04 am
Is there a way to combine this plug-in with Extend Silences https://forum.audacityteam.org/viewtopi ... 42&t=79725
so that it could find silence sections and repeat sounds between them?
genaro
Permanent link to this post Posted by steve » Wed Sep 27, 2017 10:31 am
genaro wrote:Is there a way to combine this plug-in with Extend Silences https://forum.audacityteam.org/viewtopi ... 42&t=79725
I think that could be done, however, Nyquist would need to load the entire audio file, plus the repeats and silences, in RAM. As Nyquist is a 32-bit application, the available RAM is limited to 2 GB and Audacity processes audio in 32-bit float format. It's probably not worth the effort to combine these plug-ins unless you intend to use it on a reasonably long selection, but the memory requirements of a long selection are likely to exhaust the available RAM cause a crash. So the short answer is; yes, theoretically possible, but not practical.
Next
Return to New Plug-Ins
Who is online
Users browsing this forum: No registered users and 2 guests
