Rectivert by Adam-V
Full or half wave rectification and inversion of an audio track with independent control over the left and right channels where the track is stereo.
Controls
There are duplicate controls for the left and right channels. For mono tracks, only the settings for the left channel will be used.
Rectification Type:
Determines the type of rectification to be performed.
- Half
Half wave rectification will be performed with only the top half of the waveform being kept. The bottom half of the waveform is discarded.
- Half
- Half
Half wave rectification will be performed with only the bottom half of the waveform being kept. The top half of the waveform is discarded.
- Half
- Full
Full wave rectification will be performed. The bottom half of the waveform is reflected around 0 and will appear in the upper half along with the original top half of the waveform. - None
No rectification will be performed.
Invert:
Determines whether the waveform will be inverted. The bottom half becomes the top half and vice-versa. This is applied after any rectification is performed.
Download
V1.1 No functional changes, just reformatting to common lisp standard
Rectivert.ny (1.5 KB)
V1.0
Rectivert.ny (1.42 KB)
