Vibrato
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Vibrato
Permanent link to this post Posted by steve » Fri Apr 15, 2011 11:15 am
Applies a variable vibrato to the selected audio.
Limitations:
Maximum length is 99,999 samples (per audio channel).
This limitation is hard coded into Audacity as the maximum size for *table* is 100000 samples.
Thanks to Edgar-rtf for the suggestion of using (fmosc), which in spite of the length limitation provides an elegant solution.
To overcome the length limitation, the function (snd-compose) could be used - this function uses a sound as a look-up table rather than using *table*.
Updated version: vibrato.ny
Re: Vibrato
Permanent link to this post Posted by Irish » Tue Apr 19, 2011 4:01 pm
Interesting effect, Steve.
I just took a quick look at it, and tried to get a slow vibrato (approx 1 to 2 Hz), but entering 1.0 for Initial and Final speeds gave a result that sounded like about 10Hz, and entering anything less than 1.0 didn't seem to make any difference. :?
Sorry I can't be more constructive, but I haven't yet got my head around pwlv and fmosc. Maybe later ...
POL
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
Irish
Forum Crew
Re: Vibrato
Permanent link to this post Posted by steve » Tue Apr 19, 2011 4:54 pm
Irish wrote:I just took a quick look at it, and tried to get a slow vibrato (approx 1 to 2 Hz), but entering 1.0 for Initial and Final speeds gave a result that sounded like about 10Hz, and entering anything less than 1.0 didn't seem to make any difference
Thanks for checking it out, and you're correct, the vibrato speed is too fast.
This update should fix it.
vibrato.ny
(1.7 KiB) Downloaded 1326 times
Re. (pwlv), have a play with this code in the Nyquist Prompt:
Code: Select all
(setq L1 0.5)
(setq L2 1.0)
(setq L3 0.0)
(setq L4  0.5)
(setq T2 0.33)
(setq T3 0.67)
(setq T4 1.0)
(control-srate-abs *sound-srate*
   (pwlv L1 T2 L2 T3 L3 T4 L4)
The function (control-srate-abs) srate beh) forces beh to be calculated at a sample rate of srate.
In this case, the sample rate is set to *sound-srate*, which is the sample rate of the selected audio.
The reason for having that function here is that envelopes are normally calculated at the control rate, which is normally much lower than the sample rate of the track and so the output of pwlv would be shrunk down to a tiny length when it is returned to the audio track. By forcing pwlv to be calculated at the sound sample rate, the output from pwlv will be such that a time value of 1.0 is equal to the length of the selection. (the time values are relative time values).
Re: Vibrato
Permanent link to this post Posted by steve » Tue Dec 09, 2014 7:33 pm
New version. Requires Audacity 2.1 (soon to be released) or later.
The interface is a little different from the previous version.
The default has one numeric value set for "Vibrato speed" and one for "Vibrato depth". This will give a constant vibrato at the specified depth and speed.
The text boxes will also accept multiple numeric values separated by spaces. In this case, the supplied values will be evenly distributed between the start and end of the selection, providing a smooth transition from one value to the next.
Example: Setting the "Vibrato speed" to:
Code: Select all
0 30 0
This will cause the vibrato speed to gradually increase from zero to 30 Hz and back down to zero.
Limitations:
1) This version overcomes the 999,999 sample limit and may now be used on longer audio without error. However, when processing long selections there will be a gradual deterioration in sound quality due to cumulative rounding errors (not that a vibrato effect is often used on sounds much more than a few seconds duration).
2) In common with most other time stretching effects, the length of the selected audio may change slightly as a result of processing (though usually only by a very small amount).
vibrato.ny
Version 4 plugin. Requires Audacity 2.1 or later.
(2.68 KiB) Downloaded 4382 times
Return to New Plug-Ins
Who is online
